The Neo Zero
- Oct 9, 2010
Has anyone had some hands on with this board yet?
I just recently built my new rig with this one.
If you're thinking like I was with sticking to an AMD/Nvidia Sli setup this board might be a problem if you want to SLI your GPUs unless you plan to water cool the GPU cards.
You can put in two stock cooled GTX 295s or GTX 480s but you'll not be able to use ether of the two PCI slots.
If you remove the stock HSF and put on some decent watercooling blocks you'll be able to use at lest one of the PCI slots for something.
It was just bad placement of the slots from Asus but it does run like a champ and has some niffty over clocking tools in the bios.
