M4A79 Deluxe Reliable?
Ren H
I'm looking at this mobo as an upgrade for the folks, and reliability is paramount. I haven't wanted to upgrade because, as the saying goes, If It Ain't Broke, Don't Fix It!
Well, things are broken. Time to upgrade and move them on to Vista or 7. (I'm still using 2k and Linux, btw)
I'm wondering what people here at Hard think about this board, and perhaps there is a better option from Intel? One of the reasons for going with AMD is the virtualization, if I undrstand correctly this will allow me to run XP at the same time? (A fall back for software and comfort level for the folks)
Perhaps a Supermicro Intel combo would be better, but we don't want to spend too much...
M4A79 Deluxe $225
AMD 7750 $80
Ram <$100
Total about $400 Canadian
There are less pricey options but this board has 8 phase power and 6 layer board, so perhaps this is a better option for stability and longevity.(EDIT: I should add that local power grid makes this a concern-only using APC Back UPS)
I've discounted Gigabyte as an option, btw.
I've been reading the customer reviews at Newegg, figuring that if people are having issues I've got the best chance of reading about it there due to volume of sales, and overall it seems to have the least issues but I see occassional comments about boot issues (never mind the raid, not an issue) and some integrated peripherals not working, this I am concerned about!
Can any of you uber geeks set me straight, or is this a good choice?
Where about you live, You can buy my M4A79, works here with 550 Chip and unlocks that chip as Quad with bios 1602, Ontario here
No problems here with mobo, just going with AM3
Here was my 7750 on this mobo
Here is CPUZ with that mobo and 7750 @ 3.5.....Rejected but I think its cuzz of Windows 7
http://valid.canardpc.com/show_oc.php?id=560031
Well if gigabyte isnt your cup of tea then this board would be another great choise...im running it with a 7750 @3.2 now and it does run great....the only complaint i have is the board overvolts on auto setting for the cpu,but if you know what voltage you want you can select it in bios so really its not a problem..im very happy with my setup but not being a gamer its max overkill for what i use it for...
I like a very snappy hi tech setup but thats just me...
you really cant go wrong at all with this board..
HondaGuy thanks for the offer but I think given it's for my folks I should stick with a new purchse.
wesleys_dad, I've seen you've been posting a lot around forums, I take it you've done your research!
good to hear your recommendation, seems to be typical of Asus to overvolt the chips a bit, as you say no problem really I think.
I might upgrade the stock 7750 cooler... I hear they're not so good, probably go for a Noctua, Silverstone NT, or Thermalright. (Although it does add to the price, I think it's worth it)
Unless I go for Supermicro Intel...
The board you chose is considered by many AMD enthusiasts to be the cream of the crop for its quality and performance parameters. Additionally because of it high profile status and use by overclockers it is consistently being refined from a bios development standpoint. If you are looking at a lower price point and are interested in going with virtualization I think you have made a great choice.
Hi there Juan_Jose, an Asus employee eh?
Good to see you on the forums!
There is one other aspect of this board that causes me some concern.
When I first looked at it, the heat pipe/sink implementation seemed like a good idea but for the possibility of it not making full contact due to it's spanning three areas. If there is distortion in the manufacturing process causing it to be out of flat/plane, something I could see happening quite easily, then it might not make full contact on all surfaces and potentially act as a hinderence to heat dissapation.
I would like to direct your attention to the page below:
http://www.xtremesystems.org/forums/showthread.php?t=218355
I'm still considering this board, and possibly swapping the heatsink/s for something like a thermalright (haven't checked if this is even possible yet), but of course I'm afraid doing so would void the warranty.
Also this page:
http://www.thermalright.com/new_a_page/product_page/mosfet/faq_mosfet_cooler_hr09.htm
Any thoughts?
(p.s., any interesting read, that thread,...)
