M3N-ht Deluxe problems
Kaball
Hey guys I am having a tad bit of trouble with my mobo. I bought the M3N-HT Deluxe a few months back and I am in need of some other cooling options for my cpu (9950BE). Right now I have my stock heatsink on there and I really do need to cool it down, it's not that It's "hot" per say but it is not as cool as I would like it. I also have 8GB of OCZ Reaper HPC ram. So therein lies my problem. I can not find a heat sink that will fit with my ram. I really like the way the OCZ is performing so I would prefer not to change that. But at the same time I would LOVE to have one of the new CoolerMaster V8's. Or is there something out there that I could use to cool it and still keep my ram? Thanks!
unfortunately no. That is what I bought and I preceded to "break" my mobo and had to RMA it. so now I would Like to find a new one if possible.
Thats not cool. I was just about to order a M3N-HT to upgrade my M2N32-SLi. I already have the Ultra-120 though... hmmm... I thought that would clear. I wonder why not... I suppose that rules out a duo-orb as well then too.
Looking at the board, an ultra-120 should clear the memory unless you are using some memory that has a tall heatsink on it. Ah... (read it over again)... there is your problem... 'Reaper' memory. Considering the low cost of memory, and the greater importance of CPU cooling over memory cooling, I would swap out the memory for something without such a tall profile. Then the Ultra-120 should work fine.
