Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have the M3A79T and I started off with a 9950BE cpu. I just recently upgraded to the 940 cpu. The problem is that when I try to go into the cpu settings in the bios, it locks up. I can do everything else in bios. Does this mean that I need to flash?
most likely need to update the bios.. check their site and see if there are any specific bios for phenom II support.. if so then just update to the newest bios..
