M2N32-SLI RAID-0 is Slow
HydrasunGQ
I have 4x74GB Raptors in RAID-0 on my M2N32-SLI NVRAID controller.
I tried disabling tagged queuing with no help. Can anyone suggest anything that can be causing this?
HydrasunGQ said:
I don't know but it's not like I can try that since my OS is loaded on this array.
I guess that would be a bit of a problem, eh?
well then:
What windows version are you using?
Which version of the nForce drivers?
Have you tried any other benchmark?
Does it feel sluggish to you?
well then:
XP Pro SP2
nForce 9.35
I haven't tried any other benchmark. I'll give Sandra a try and report back.
It doesn't feel sluggish but it doesn't feel as fast as it should.
OK, this is what I got with Sandra
OK, I found the problem. I broke up the array and benchmarked the drives individually and found the culprit.
one out of the 4 drives may be bad.
had a spare Raptor so I replaced and reinstalled the OS on the array and now i have much better results. :D
Damn, it must be fun to do pro work and get to have toys like that.
