M2 SSD vs older SSD for OS
ZacharyS
I am planning out a new build and wondering if it will really matter which SSD I use as my boot drive. Currently I have a 256GB samsung EVO and a 1TB sandisk SSD. I use the samsung for OS and the sandisk as a steam drive.
In my new build I want to get a M2 SSD and I was wondering if it would even be noticeable having the OS on that vs my samsung ssd. To be perfectly honest, I don't care at all about boot speed. I reboot only a couple times a month if at all. But for just general purpose usage, is there any advantage with the M2 drive for the OS specifically?
I just went from a 1tb 850 evo (OS, only drive in system) to a 1tb 960 evo (OS, only drive in system), and I don't notice a damn bit of difference. I guess it's nice not having a sata cable anymore and being able to completely remove the sata power cable string from my modular PSU.
You won't notice any real world difference.
Use your money on a more worthwhile upgrade (monitor, GPU, audio, storage capacity, chair, desk, peripherals, in that order)
Yeah, since I ordered a new system and own the 850 1tb EVO, I decided to only get the 256Gb 960 EVO for my O/S drive, and keep my 850 EVO 1tb for all my storage/applications/games to install too. It will help boot speed by a little bit, but not much else. :)
The only computer that I have that has a m.2 drive being used is my FreeNAS system. I didn't purchase it for speed or faster boots, although it is better (and more reliable) than a USB drive. I just wanted to use all eight SATA ports for large hard drives in a RAID-Z2 configuration, and that left zero free ports for a el-cheapo SSD.
The real-world price/performance ratio between a similar SSD and m.2 drive just isn't there.
I've noticed real world performance difference FOR SURE. Programs that are held back by Disk IO are improved. Programs that are NOT well.. they are fine.
I went from an 840 pro SSD (on an old ass motherboard for my 2600k) to a 960EVO NVMe PCI 3.0 x 4 1tb and the speed difference for I/O related issues are night and day. BUT... you need to understand the difference and what I/O is bottle necking your system.
if you hate that little lag when popping a new menue, or that slow non instant boot times, or that loading a game should be faster.. or loading a detailed image or cad drawing should happen faster (provided you have controller/memory and CPU in order.) then you will love NVMe.
If you don't feel constrained by Physical I/O then NVMe is an expensive boost you will not appreciate a lot.
So.. lets break down your use case.
1. You probably game. No big.. all of us well most of us do.
2. This isn't for an enterprise solution so no big deal there.
3. I/O type. What are you waiting on to load/process/run. Game load times, level loads, pauses in game to load data for older games.. even some newer games. All of these will be improved. If LOAD times are you bane and they are NOT network based.. then a good fast NVMe improvement will help.
4. Real world use case. What do you do and where do you feel pain in your use? If you LOVE a snappy system that feels like everything is loaded all the time NVMe will bring you closer to that. If you don't care about a pause.. or a load screen, or they are within tolerance for you. Then spending the extra money on NVMe storage is NOT worth it.
It comes down to HOW you use your system and WHAT you want to gain or fix that is a problem for you in your system.
There are benifits to running an NVMe Drive in PCIe 4.x. Your system will not be able to do anyhting MORE with ti than with an standard SSD. It will just get to the point of doing it a bit quicker. I would say easily 30% faster given other components and I/O types involved.
Actually, my friends recently formed a computer and I saw his specification
I am wandering the same question, is that really big deal between M.2 and SATA3 SSDs?
I would not recommend my friend to use M.2 for regular user because I think budget always decides what you are going for
So far I think 1500MB/s and more than 500MB/s are no different for me (it is just the number and faster within nano-seconds)
Regarding to the usage, I think you need to think if you are a multi-tasker or just a regular user for occasionally gaming and working
For me, 500MB/s is good enough for me and I am the person who upgrade my PC from HDD to SSD
SSD is like toxic for me, you won't turn back once you tasted the sweetness of NAND speed :)
Absolutely, especially the NVMe PCIe M.2's. Once you go down this path theres no coming back.
For the OP, remember that M.2 is just a form factor. For example, A M.2 Samsung 256gb EVO 850 SATA III is just like a 2.5" EVO 850 in terms of speed. The real difference in performance is with M.2 PCIe NVMe drives
Just received some of my parts today, including my 960 EVO m.2 Samsung 256gb SSD. :p
QFT!
I was a bit skeptical, 1, at the work I needed to do with my BIOS to get it to work with an NVMe drive, and 2, if there would be a discernible difference going from a SATA III SSD to the SSD in my sig. Easy answer - YES! I'm getting drive speeds, boot times, load times, etc., that I honestly wasn't expecting to be as dramatic as what they are.
Those high-end M.2 SSDs are only great if you're dealing with volumes of data. But, if you're just using it as a boot drive, you really cannot tell the difference. If there is, it will just be a couple of seconds faster, but still not that much.
No offense here meant, but unless you have actually FELT the difference you have no idea what you are talking about. How can I give an example that will help you understand.. Oh I KNOW!
Ok boot up your PC into windows 10. Log in.. look around and see how long it takes to actually finish booting up. Got a good idea. (Even on SSD.)
Now without spending a dime go to your local Microsoft Store. ( I know.)
Now take a look at a surface book. Shut it down.
Now turn it on. How long does it take to boot and be ready for you?
THAT'S WHAT IT'S LIKE FOR EVERYTHING!
(Because surface books are using pcie storage. Probably not even as fast as the good Samsung drives like what I have.)
Keep in mind you CAN get a tratbyte drive... and run EVERYTHING off of it. Like what I am doing. And I'm just LOVING it.
Yep, I have an 850 EVO 1 tb in my gaming system now, and my Surface Pro 4 booted almost instantly compared to it. It was night and day.
I will get to experience it either tonight or tomorrow night once I finish building my PC.
I actually avoided M.2 Drive because the resource cost of installing it on my motherboard means that I would lose access to 2 of my Sata ports, even if the M.2 is Sata, not PCI-E, which is ridiculous cost.
I am one of those people who would NEVER use just the one drive if I can help it. My past experiences with installing only 1 drive always ended badly, and M.2 is even worse because how PITA it is to get to if the system is bricked and I want to get the data out before I do a clean reinstall. My first SSD contains OS, only ever OS, that's my sacrificial SSD that if my OS is bricked, that would have no effect on my data files, because they are all located in physically different harddrive. I tried partitioning a single drive before, but unfortunately whenever system reinstall is involved, keeping that second partition intact is never guaranteed for some really strange reason.
The resource cost is no longer an issue as installing M.2 should no longer use up your SATA ports on the latest chipsets.
If you go M.2, don't do M.2 SATA, do NVMe M.2.
Thank you for your clarification and yes.
PCIe is way faster than SATA. However, the price is enormously high for regular customers, like me.
As I don't feel any different 1500 and 500MB/s, I will stick to the combination of HDD+ SATA3/m.2 SSD.
Even though you got the best specification, HDD can be inherent for the next-gen PC.
I think SSD, for now, is treated as consumer items and it may be gone after few years (but still, it depends on the user behaviors).
So, I fired up my new PC last night, Went from an i7-4770k with 850 pro, to a i7-7700k, to a 960 evo, and it's night and day. The speed of that drive is crazy fast. Only took 10 minutes at hte most to install Windows 10 Pro.
Anyonne who said that there is no speed difference noticeable has no clue. It was very obvious.
Isn't that about same for an 850 pro? I mean if you Secure Erased the 850 pro on the same system and did an install I would not expect a night and day difference.
No, the 850 Pro took me between 20-30 minutes. There is a huge difference between both the drives in speed. The difference feels like going from spinning disk to an SSD. That is how it feels.
Enterprise SSDs are always WAY faster than consumer SSD's. My good old, well used Intel S3500 beats the crap out of any NVME consumer SSD. I see around 5x - 40x better performance when dealing with a lot of random io, especially writes.
New system built. Ran a speed test comparing my 850 EVO to my 960 EVO. Enough said.
