m1015 + Solaris 11 E = no boot, GRUB!
brutalizer
I have inserted the IBM m1015 card into my PC, and when I boot up, I can see the m1015 card. It asks me if I want to boot web bios and something else <CTRL+Y>.
I dont do anything and wait, and suddenly it drops into grub. That is all. And the characters are weird, when I type a few letters, some strange characters are shown.
If i plug out the m1015, my PC behaves as normal. The m1015 screws up boot from my disks. I tried to boot from Solais 11 Express Live USB and that does not work either, I only get droppped into grub. And there are same weird characters.
What can I do?
UPDATE, there seems to be a problem with Gigabyte mobos? I have a P45 Gigabyte EP45-DS3P motherboard.
http://www.xtremesystems.org/forums/archive/index.php/t-264900.html
"Gigabyte and LSI have compatibility issues. I found multiple cases on-line. I could set-up and run 9260 and 9240 RAID on 890gpa but Win 7 would not install on it no matter what. On TweakTown forums there was floating beta BIOS for one of the older chipsets (P45 or X48) that fixed Gigabyte and LSI compatibility issue. One of the reasons I switched to ASRock is that it runs fine with LSI..."
If I could flash it to IT mode, would my Gigabyte mobo work? Will IT mode remove any incompatibilities?
My Gigabyte P965 also failed on me, I even got a Beta-BIOS from gigabyte which did not fix anything.
However on my new P67A the IBM M1015 works fine. So older Gigabytes are severly broken in respect to LSI, which just sucks.
Windows says:
"No physical memory is available at the location required to load the Windows Boot Manager. The system can not continue."
Which seems to be well known problem with no solution. this sucks big time. I must change the mobo? Is it that bad?
no, it is because the bios is unable to properly initialize the card, reserver memory for it and such. you can not do anything about it.
It was hard but I had to surrender 6 months ago...
It's not just gigabyte, it's pretty random. Mine doesn't work on my P35-DS3P Gigabytes, nor on an old DFI NF4 SLI. Works fine on my Asrock X58 Extreme and MSI X58 XPower Big Bang.
