One of my friends wants me to build a M-ITX system for him.
Light gaming, light photoshop/after effects work, heavy web browsing, also used as an HTPC
~$750, very flexible
3) Where do you live?
Columbus, Ohio (near a Microcenter)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything (no monitor needed), except whats listed below
HD5750- This is what he has... http://www.newegg.com/Product/Product.aspx?Item=N82E16814161309&cm_re=hd5750-_-14-161-309-_-Product
USB BDROM/DVDRW, USB/eSATA HDD
Keyboard, Mouse
6) Will you be overclocking?
No.
22" 1080p LCD, and 1080p projector
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
eSATA, SPDIF, M-ITX form factor, 1x PCI-E x16, ability for 4GB of RAM (don't need any more), would like a 1156 based setup if possible
10) Do you already have a legit and reusable/transferable OS key/license?
Windows 7 x64 Home Premium
Here's what I've come up with so far...
Case: LIAN LI PC-Q07- http://www.newegg.com/Product/Product.aspx?Item=N82E16811112227 ($75)
PSU: CORSAIR 400CX- http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008&Tpk=400cx ($50)
CPU: Core i5 750 at Microcenter ($175 after tax)
MITX Mobo: DFI LANParty MI P55-T36- http://www.newegg.com/Product/Product.aspx?Item=N82E16813136073&Tpk=itx 1156 ($140)
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161309&cm_re=hd5750-_-14-161-309-_-Product ($0- already have it)
RAM: Corsair XMS3- http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260&cm_re=ddr3-_-20-145-260-_-Product ($95)
HDD: WD 640GB Blue- http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218&cm_re=wd_640-_-22-136-218-_-Product ($70)
ODD: (none)
Sound: EMU 0202 (~$100)
Keyboard/Mouse: Has a set already.
Total is about $700 I think.
As usual, rip it apart...
Keyboard, Mouse
No.
ASAP
ODD: (none)
