dabiggoober
- Feb 27, 2004
Thanks in advance for your time and help.
I built the following system for a friend (my boss actually).
GIGABYTE nForce3 150 Motherboard "GA-K8NNXP"
AMD 64 3200+
2 37GB Raptors in Raid Zero (thanks to hardocp users for the help setting up raid)
1 200GB IDE 7200 8mb cache
1.5 GB PC 3200 Kingston
2 52x read CD's
1 8x DVD multi format writer.
1 ATI 9200 PRO
As you can see the weakest link in this system was the old video card we had scrounged from his previous system.
I convinced him the 9600pro was now a great bang for buck card and we bought one made by powercolor that had nearly all positive reviews from newegg purchasers.
Put the card in and install the drivers that come with card and Card hangs on Medal of Honor and Tiger Woods Golf04. Things we've tried:
1) Catalyst drivers on CD
2) Latest Catalyst build from ATI
3) Remove all video drivers and repeat 1 and 2
4) Try running under safe mode
5) Flashed latest bios build from Gigabyte (v12 i think)
All cause machine to hang or get the VPU recovery failure depending on which version of Catalyst drivers we are using.
Finally, I went into the BIOS and changed the AGP settings to 4x from Auto. NO CRASH RUNS GREAT
Changed from 4x to 8x got crash
changed from 8x to auto got crash
changed back to 4x runs great.
Now, I know that nearly all games don't use 8x AGP yet, but still, this seems like something I want to fix.
So, after all that, is there anything else anyone can think of me to do or any advice on whether I should RMA CARD and get different manufacturer or RMA board and replace?
Also, btw, I took the card and put in a p3.0 machine at work to see if I could get it to crash and ran fine with no change in any settings. So it would appear it is either a MB issue or a hardware compatibility issue in general.
Thoughts?
Thanks,
Dabiggoober
_____
Lottery: A tax on those who lack math skills
_____
AMD 64 3200+
2 52x read CD's
1 ATI 9200 PRO
Thoughts?
Thanks,
Dabiggoober
_____
_____
