M/B won't detect 128bit card
Crucible
Hello.
I think my friends mobo has problems.
It is a Gigabyte GA-8IPE1000 Pro2.
It no longer recognises the Leadtek FX5900XT video card.
It will not boot with any 128 bit card, we tried three different cards.
It will run with 64 bit cards.
Current specs are:
Intel P4 3.2 Prescott
Corsair TwinX1024 - 4000Pro memory
Leadtek FX5900XT graphics
WD 200 GIG 8Mb cache
WD 120 GIG 8Mb cache
Liteon DVD 16x
48x CD-RW
OS is XP Pro.
Do we need a new mobo?
Make sure all power connectors are attached properly and securely, including the main ATX 20pin connector, the 12V ATX 4pin power connector, and the external power connector on the video card. If you have a bunch of other crap sharing the video card power line, you might want to swap them off it and/or get rid of the y-splitters and make sure they're actually plugged in.
If that doesn't work you should check your BIOS settings and probably start by resetting them to default. Also, make sure you're not overclocking and accidentially overclocked your AGP bus speed.
Well, that's where I would start anyway.
We pulled the sys apart and re-seated/connected everything.
The power connectors seem to be attached properly.
The PSU is Antec 300w, three months old.
The mobo is nearly two months old.
Perhaps the PSU is inadequate for all the gear on his rig?
Try just powering up the motherboard by itself and the video card, without all the drives... See what happens.
