M.2 to USB
haggggler
can someone suggest a good one? I need a way to test these cards for errors on a machine that doesn't have the m.2 slot.
thanks
define: m.2
if they're SATA3 based ones than this one should work. I own one, worked well enough for me though I only used it for maybe an hour to get a smaller SSD imaged to a larger one for an upgrade on the tablet. It works but it feels a bit cheaply made, it does come with the tiny screwdriver you'll need though. (I didn't use it, I already owned philips heads that small)
If it's a PCIe based one than i'm not sure if there's any that will work.
