M.2 to M.2 imaging/duplicating?
Copyright
I need to know what it would take to move an image or somehow duplicate data on one m.2 to another m.2 of the same size. These are NOT the AHCI version.. OCZ RD400 to OCZ RD400. I have a stand alone duplicator but not even sure it can duplicate a UEFI install. I would also need an adapter to make it work on SATA. Thanks for any feedback!
A pair of these loaded with the m.2 in my dock was my theory on how to duplicate.. Not sure if the OCZ RD400 would recognize or not.
http://eshop.sintech.cn/m2ngff-sata-key-bm-ssd-to-sata-adapter-with-case-p-970.html
The RD400 is a NVMe PCIe m.2, the adapter you specced is a simple SATA form factor converter and would only work with a SATA m.2
Yeah that was my main question is there a way to adapt to SATA for docking duplication but I also remembered I have a pcie m.2 adapter for PCIe slot... I can shove a m.2 in that and probably use the Samsung SSD Clone software to copy over the OS.
Bingo! That should work just fine.
