M.2 Adapter card
Redmud
Hello,
I have a fairly old motherboard, MSI Z97 Gaming 5 and would like to put in an M.2 drive while the board does have an M.2 slot it is an older interface. I was thinking of possibly getting a PCIe adapter card and stick that in.
Currently I have an SSD for the boot drive an a HDD for my data (all game data). Would this be a viable short term? I plan to get a new system Q1 of next year so the m.2 drive would move over there. My concern is I do not want to impact the Video card so I am not clear on if sticking another card in a PCIe slot would be bad. The thing here is I have money to burn now that I may not have later.
Thanks
I added a samsung M.2 to my old x79 platform, it's really fast with a 2080ti, only issue I had was I had to patch the BIOS to be able to boot from it.
Just put the m.2 in the mobo slot unless you are using the bottom sata ports. As devex said, you are unlikely to notice a difference unless you need more than 800MB/s. However, your board does support running x8 x4 x4, so you could run 2 drives in adaptors off the cpu pcie if you really wanted
FWIW the bios 'hack' isn't hard, and isn't an actual hack but really a workaround to put in normal UEFI functions in because vendors abandon stuff so damn fast.
I mean if you're going to point at a $400 card just to boot from it, would make far more sense to just upgrade the platform.
Even 4x4 bifurcation cards are around $50 and work in good modern boards with superior software defined storage, the old RAID vendors are stuck in the past.
Reactions: mikeo
