LVM-37W3 died, need replacement advice.
kraken0698
Well, my Westinghouse LVM-37W3 died the other day. :( No picture, won't even turn on. I have tried everything, to no avail. It's out of warranty too. Looks like I am stuck with getting a new one. After having that 37" monitor for over a couple of years now, I can't see myself getting anything smaller.
So, I could use some advice on some of the best 37" 1080p TV/monitors out there right now. I would go with another Westinghouse, but I want to move up in quality. My Westy didn't have great contrast and the black levels were, well... grayish. I have looked around a bit and see that Sharp, Samsung and Toshiba all have good looking sets. However I want to make sure that this monitor will be able to display text as well as the Westy did and will also look good when playing Xbox 360 games, something else my Westy did a poor job of (possibly due to lack of good internal scaler?).
My ideal budget would be under $1000.
Any suggestions would be appreciated.
Yeah, that might be a bit much. I only sit about 2' from the monitor, so 47" is too much.
I have found a few that look promising however:
Samsung LN37A550
http://www.amazon.com/Samsung-LN37A...8?ie=UTF8&s=audio-video&qid=1210291376&sr=1-8
LG 37LB5DF
http://www.amazon.com/LG-37LB5DF-37...1?ie=UTF8&s=electronics&qid=1210295560&sr=8-1
Toshiba REGZA 37RV530U
http://www.amazon.com/Toshiba-REGZA...1?ie=UTF8&s=audio-video&qid=1210297850&sr=1-1
Any suggestions on any of these? Are there others I should look at?
