lvds troubles
Mikan
Hi all, I noticed there's lots of help here, so I thought I'd give this a shot and hopefully I'll luck out.
I've been trying to get a working lvds setup going for a long time.
I bought the controller off ebay and have had tons of trouble getting it to work. It didn't come with the right configuration for the right lcd that I was able to determine looking at the data sheet for the lcd.
I have 4 or 5 types of lcds, and have had some success with it working on other types in the configuration it came with, but I really want to get a 15 inch lcd to work, a lp150x05 (a2).
I
can tell with a voltmeter that it is outputting signals the way it should be, and I can test with the original laptops the lcds were meant for that they're working, but can't find the right pinout.
Here is the data sheet for the lvds:
http://www.sdlcd.com/驱动板/RM3501B_2013B中文规格书.pdf
The key set of pins is cn12 it appears, but it's missing what I think is crucial information about what is the ddc data and ddc clock wires.
Here's the datasheet for the lcd:
http://www.datasheet.in/datasheet-html/L/P/1/LP150X05_LG.pdf.html
The guy I bought it for is having to act as a middleman from the factory and having a difficult time finding any info..so any help would be appreciated.
Thanks!
