Lucid Virtu Question
updawg
Question about this product: Does Virtu let you use your dedicated graphics card processing power and allow you to use the hdmi out on your motherboard? I have a low profile case that doesn't have a pci-e slot, but I was thinking I could remove the connectors off a low profile 7750 and be able to fit it inside my case. This was I could get the additional graphics capabilities and just use the hdmi out on the motherboard.
That's actually a really good idea!
I can't answer the questoin though, as I never used Lucid nor have I ever looked really into it.
