Hey guys. As always thanks for being here and I thank you in advance for your time. I recently bought a coolermaster 690. Awesome case btw. So I was transferring over everything and this morning I have been unable to keep my temps down. Normally I run 60 orthos with e6300 at 3.15 ghz.
So today that was my idle temp at stock speed when I noticed my cpu fan was only going 500 rpms. I went into the bios and checked my settings, normally I have the fan controls disabled. Reset the arctic freezer pro but noticed the fan really was stiff. Much more than you would expect, especially in relation to my case fans.
Took if off, opened the middle of it, there is a black plug and I sprayed some WD 40 in it. Immediately it loosened up. Now my rpms are 2600, temp are 36 idle and 50 load (at stock).
So my question is, I thought these fans did not need lubrication? The WD 40 isnt going to last forever and I dont want to risk my fan going out again. Should I just replace the arctic freezer pro? I have only had the fan about 9 months. And to be honest I usually idled around 40-45 so I am thinking I may have gotten a faulty fan. Can you only replace the fan on the heatsink? It is held on by rubber grommits that look to be a part of the design,
Again, thanks a million.
