Lubic, and the alternitive
WillyWonka
Hello. I'm new here, but I'm sure you all know that. Any how my problem is that I'm looking for something simaler to the lubic custom cases build by Aerocool. I like the concept of using aluminum rails for building custom cases. What I was wondering is, would anyone know where to find, and buy the same kind of rails or railing system like you get with the lubic case kits. I'm sure there is a metal alloy company that actually manufactures those rails. I just cant find it.
Thanks everyone.... The willy.
From having built similar things before, sometimes the best price is to get the kit if you can reuse the parts for your project. Good luck!
I'm 90% done with this one:
I understand the power of google. The question was implied because I'm trying to get away from using aerocool products. If I can find the same kind of stock with in the same size, and diameters as that which aerocool uses for thier frame ideas. Then that is what I want to use. So the question above is still the one I'm intersted in having answered, but with out going to the aerocool product.
Thanks again every one
The willy
