TheAMAZINGNorad
- Dec 23, 2002
I have a Westinghouse LTV-27w6 hooked into my PC for gaming and movie watching @ the dorm. While it works great 95% of the time, I noticed some problems rendering red. When I hover over the forum link @ overclockers.com, it seems almost as if there is a double image! All of the red text seems a bit blurred. When I switch over to 1024x768, it goes away and is clear as daylight. I have tried using the VGA input, but the screen looks like a gausian blur has been applied: everything is fuzzy! When I use my DVI-> HDMI cable, i get bands of sharp and fuzzy on the screen. Is this my TV, or something with the website or text generation which is causing this wierd double effect on all red text. Any ideas?
Update: The blured red text dissapears on ALL resolutions with the VGA input, but everything still appears ever so slightly blurred and washed out. HDMI is totally hosed and showes the red effect at all resolutions. SHould there really be such a huge difference between VGA and DVI?
