I recently purchased an LTO drive and am buying misc LTO tapes. Some are new, some are used. What is the word on used LTO tapes? Also, what is the best way to verify that the tapes will hold data and that the data written to them is correct? For my use, I will only be writing to each tape once and then storing in case one of my HDs dies, in which case I will use it to restore.
Side question, how do you know when you need to clean the tape drive with a cleaning tape?
Thanks in advance!
Thanks in advance!
