LSR MKII Replacement Components
rabidz7
Where can I get replacement woofers and tweeters for these speakers?
upon further looking, jbl says they are not serviceable. are you able to open them? maybe jsut grab the part numbers off the magnets.
Might also be able to find some on ebay. Could find some being offloaded for different problems like an input is broken or power supply is bad. Then harvest the speakers from it. Not sure how they are mounted internally so you might have to be creative with some power tools.
