LSI2008-it not detect any more
arryo
So I decided to reinstall my ESXi box and after have 5.0 U1 up, it didn't recognize my IBM M1015 (flashed to IT mode) any more. I even tried to install VMware ESXi 5.0 Driver for LSI MegaRAID SAS Controller 5.34 but it's still undetectable.
it used to work out of the box before and i have not changed anything in my system.
my system: mainboard: X9scm, e3-1230, 16G ram.
after trying different pci slots, there's only 1 slot that recognizes the card (the furthest from CPU). The other m1015 card in the other slot still not detectable even thought lspci correctly shows 2 cards:
000:002:00.0 Mass storage controller: LSI Logic / Symbios Logic LSI2008 [vmhba2]
000:003:00.0 Mass storage controller: LSI Logic / Symbios Logic LSI2008 [vmhba3]
Built a small VM box using this motherboard this past weekend and an Adaptec 6805. Same type of thing. The card wasn't seen on POST. A quick search on Adaptec's site mentioned update the BIOS but if the issue remained, try setting Advanced -> Chipset Configuration -> Integrated IO Configuration -> PCI Express Port -> PCI-Express Port GEN to "Enabled" (see http://ask.adaptec.com/app/answers/detail/a_id/17203/kw/X9SCM). I updated the X9SCM BIOS to the latest version, reset to defaults and all was well with the world. I think I remember there being more options for this particular BIOS setting than just "Auto" and "Enabled" but I could be wrong.
Anyway, maybe it'll help get that LSI controller detected again.
since I have one card detected already and I only need 1 card for my datastore, the other one for passthrough. I'm a little bit scared to upgrade bios.
