I bought a new LSI MegaRAID SAS 9361-8i raid card and will be pairing this up with 6 WD Red 4 tb drives. My new raid card came without any instructions and just had a warranty card and basic handling instruction cad.
Card Link
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118231
The SAS cable to sata cable is a 1.0 meter internal cable SFF8643 to x4 SATA HDD (mini SAS HD to SATA data port). The thing that has me a bit confused is it has a fifth connector that has an 8 pin female end. It reminds me of a front panel usb 2.0 lead that you plug into a motherboard. I'm assuming that this is a hard drive breakout cable which indicates via an led light that a drive has failed. Does this sound right, and if so does anyone know of a breakout board that has these LED indicators that I can mount inside my HTPC chassis? If not then I'll just tuck it aside, but I wouldn't mind adding this feature.
http://store.lsi.com/index.cfm/Internal-Multi_Lane-Cables/All-Cables/LSI00411/
The end looks like the one pictured below (different brand has 10 pin female end where mine has 8)
http://www.newegg.com/Product/Produ...03242&ef_id=Uu6n9AAAACa95NWE:20140311171024:s
Card Link
