LSI MegaRaid Optimal Settings? Raid 5
smidley
I've got my new server up and running, but my drive speeds seem a bit slow. I've never used an LSI raid card before and there are tons of options, so I was wondering if anyone had any advice as far as how I should look at the settings. I have the LSI MegaRAID SAS 9260-16i card. And using the Norco 4220 case for a SAS backplane.
I currently have the following setup:
1x 1TB SATA drive plugged into the motherboard for the OS.
7x 2TB SATA drives plugged into my LSI MegaRAID Card for storage in RAID 5.
When I transfer a 7GB file from the OS drive to the storage Raid, it starts at about 40MB/sec, and then drops down to 10MB/sec for most of the transfer.
I'm using the same drives that I was using on my old Dell Perc raid card, but I'm not sure why this new card is so slow. So I'm guessing there are some settings somewhere that I need to configure to help this. There are tons of settings, and I'm not too sure about any of them since I'm a novice with the card.
So, I just made a change to the write policy on the raid controller. It was set to Write Through, since I don't have BBU on this controller. But then I set it to Write Back mode. Now when I copy files it's WAY faster. It starts out at over 1GB/sec and then goes down to around 300MB/sec. Copying files around on the array itself yields the same speed results.
Not sure why it bursts so high in the beginning and then falls slower, but it looks like I'll need to get a BBU for this card.
