Hey,
i am using an intel RS2BL080 controler with a RES2SV240 expander.
Teh setup uses 8* 1TB WD Drives in a raid 6
and 4* 2TB WD drives in a raid 5
One drive in the raid 5 makes problems. the raid web console gives me the following in the attachment told errors. one is a "crc error" the other one tells something about "Power on, reset, or bus device reset occurred".
so i now try to make a rebuild because the controller putted the drive offline. but while the rebuild it seems to continue to give me these errors.
so con anybody tell me what i have to do to get the "optimal" status for the arrays?
Is the drive dammaged (sectors for example)?
sorry for ma bad english. i am from germany
thanks a lot for your help
PHP:
ID = 3012
SEQUENCE NUMBER = 364066
TIME = 11-07-2011 22:00:38
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Port 0 - 3:1:16 - Power on, reset, or bus device reset occurred, CDB = 0x2a 0x00 0x00 0x7c 0xac 0x00 0x00 0x02 0x00 0x00 , Sense = 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x29 0x00 0x00 0x00 0x00 0x00
ID = 2740
SEQUENCE NUMBER = 363015
TIME = 11-07-2011 16:12:13
LOCALIZED MESSAGE = Controller ID: 0 Unexpected sense: PD = Port 0 - 3:1:16 - Information unit CRC error detected, CDB = 0x28 0x00 0x23 0xab 0x5c 0xc6 0x00 0x01 0x00 0x00 , Sense = 0x70 0x00 0x0b 0x00 0x00 0x00 0x00 0x0a 0x00 0x00 0x00 0x00 0x47 0x03 0x00 0x00 0x00 0x00
