Any advice would be appreciated. Just bought a LSI 9305-16i from fleabay. Flashed the firmware to 16.12 (latest), but noticed when I run smart tests through it (on windows atm), the drives instantly pass...whether it be short or long. When hooking the drives up directly to the mobo, problem vanishes, and can run smart tests as intended, and they take their normal duration to run.
First time using an HBA, so not super duper familiar with everything if there are some quirks with them, but this just seems too weird. So hoping someone has some insight for me here. Originally flashed with the windows sas3flash utility, but to be safe also reflashed with the sas3flash.efi variant via EFI shell...Still the same smart test issue. Drives function as normal aside from this weird phenomenon. Getting full bandwidth simultaneous across 12 drives in CrystalDiskMark. Also drives are passing along smart information, serials, models, etc...all working as intended...Just this smart problem when drives are hooked up to the HBA. Have tried Hard Disk Sentinel, and western digital's provided software for diagnostics...Both pass instantly. Scratching my head here on this one...
