LP3065 or 2709w? Which to get?
Mysteriouskk
Is this an easy choice or is it difficult?
Which one should I get if I like to watch movies and go online?
Normal DVD or 1080p? The HP rez will make normal DVDs look like s**t because of the pixels stretching. The 27" not so much.
Your question is vague.
Watching movies and going online - 2709w
Gaming (provided you have a powerful enough system), multi-tasking office work, and photo-editing - lp3065
The 30 inch is definitely an excellent choice for overall performance, especially since most of the top end video cards can handle the resolution just fine now.
Does it matter if the 3065 is a year and a half old? Does it still perform as well as the 2709w?
Are you buying a used 3065, or do you mean that it's been on the market for 1.5 years? I'm leery of buying used LCDs. If you meant the latter, then there's no cause for concern. The Dell 3007 has been available for several years and it's still selling well.
For your uses, I'd go with the 2709.
If I got the 3065, I would buy one used and then get it replaced with a new one or something.
Currently I'm using a 2001fp, but not as full native resolution. I can't really stand looking at 1600x1200 on a 20in monitor. If I got the 3065, would I have to run it at its native resolution?
Would the 2709w be better on my eyes?
If I'm not use to a dot pitch of .25, would it be bad to get the 3065? Right now I like using a dot pitch of 0.284 - 0.3.
2709 would most likely be easier on your eyes, but this is very subjective. If you don't like the 2001's native 1600x1200 resolution, then you probably will be unhappy with the native rez of the 2709 and 3065. The best thing to do is visit a Best Buy or Circuit City and view these resolutions in person before dropping any $$.
Yeah, it seems 100% pointless to get one of the high res 30" panels and run it at non native resolution. Complete waste. If you don't like the 20" at native you won't like this at native either, since it has essentially the same exact pitch.
The 27" has much bigger pixels, you can probably run this at native res.
I'm about to buy a LP3065 but what do you mean with "stretch". Why wouldn't I be enjoying my movies on the HP. Is it because it doesn't have a scaler ?
For your information I will be watching 720p\1080p and regular Xvid.
