I have the DFI Lanparty UT NF4 SLI-D board.. and only one video card atm.. i was wondering if it made a difference as to which pci-e slot i used while only running one card at a time?
yes...i believe that if it is in single vga mode, the top pci-e slot (closer to the cpu if im correct) runs at 16x while the other runs at some other speed
basically, yes it does if ur using single, and if ur in SLi, they both run at 8x
In the ASUS brands the slot closest to the CPU is generally the one reserved for a single card. Does this MB have a manual bridge or a software bridge????(to enable SLI??)
If so it will point you the way.
When all else fails.....look under SLI in the manual.
thanks for your reply.. i posted the same thing on dfi-street.. all i got was a reply stating "search" i mean, i would say that at one point or time most questions that people ask, have already been answered at one point on the forums.. anyone could search, but if it wasnt for the repeat questions.. wtf would we have to do on here? its not google, its a fucking forum.. god i hate going over there.
