Ok, here's the deal:
My computers put out too much heat.
My primary PC is listed in my .sig, and runs pretty much 24/7 running P2P stuff if nothing else. Monitor and hard drive power savings are enabled.
My house is two floors with central AC and heating. The thermostat is downstairs, and heat rises. The thermostat is set to 65. I cannot take it much lower because it gets cold enough in my bedroom at night as-is.
Even with the wndow in the computer room open and a fan blowing in ~60 degree air, it is consistently 75-85 in the room depending on computer use.
Other things being powered include a router, printer, cable modem, and two 15W flourescent lights. As well as a TV occasionally.
I also have a second computer, an Athlon XP 2100+. I am running CPU cool on it but it did not change anything appreciably. Underclocking the multiplier or bus speed results in an inability to POST and requires a BIOS reset. Unclocking the video card in that PC (Radeon 9800 Pro) prevents the computer from booting. So that computer stays off most the time.
With the second computer on the room heats up to like 85 degrees. I consider anything above 72 or so to be uncomfortable.
The heating vent in the room is closed and blocked off.
Anyone have any suggestions? I could buy an A/C for the window, I guess, but was hoping to resolve it without a higher power bill.
The only time the room's stayed cool is if I shut the computer down during the day, which doesn't do much for my P2P downloads.
