Lowering Gigabit Ethernet Lan speed
Ranger
Trying to find out how to lower My gigabit lan speed from 1000 mbps (which Im pretty sure its set to try and run at right now) to 100 mbps
any thoughts? MSI board
Um...that speed is auto set, if you have gigabit, then USE it...if you have a 10/100 router or modem, the lan port on your mobo will set itself at 100tx.
yeah what he said
The ports auto-negotiate, which means they choose the appropriate speed.
If one is 10/100 and one is 10/100/1000 they will both run at 100Mbps
