I just put together a small ITX system with some spare parts and I'm stuck with a cooling issue.
I'm using a small case enclosure (Wesena ITX chassis) with very limited airflow. I'm running a Intel 3770S (TDP 65watts) with a Gelid Low Profile CPU cooler which is able to cool a cpu with a TDP of 65 Watts. Currently, the cpu temps are 47-51C idling. Would it be possible to underclock/undervolt the cpu to get a cooler temp? If so, what is the best way to do so?
Intel 3770S
Asrock Z77E-ITX
Gelid Slim Silence i-Plus (CC-SSilence-iplus) CPU Cooler
Intel 3770S
Asrock Z77E-ITX
