Long story short, I graduated college and finished fireschool and am working to save up money for a place. Once I get hired on at a department I will have much more income to work with at which point I plan to build a new, nice system, where I can afford to buy some decent stuff (aka the 2,000 build). In the meantime, with games like Oblivion coming out soon, I want to know what there is I can do to maximize my system in terms of buying a cheap component here or there. I don't really have a budget perse but If I knew I could truly boost performance significantly, I'd be willing to spend $200. Can't afford much more and there is no point in upgrading a machine when I'll build a new one in a few months.
HERE'S WHAT I HAVE :
Abit KV8 Pro, Amd 64 3000+ Newcastle, never OC'ed, stock cooling
1 Gig Kingston Valueram
Sapphire x800 XT PE
HDA Digital 7.1 Gold
Dell 2005 FPW
I've done a few software tweaks, simple stuff like format/defragging, tweak windows display options, nothing big. I've never overclocked before but woudl be willing; I read some of the FAQ's and at appears I won't have much luck,( 1- my cpu doesn't seem to have a much higher limit than 2.2, ghz ( 2- My ram most likely won't overclock much. Then again I haven't tried so I don't know.
I average around 40 fps in CS:S on 1680 x 1050 with high settings. I usually forgoe any shadow options to save on the CPU. (Also, Side question, I've lowered resolution of the game before but haven't noticed a huge increase in FPS...is that because that my CPU is bottlenecking my videocard? I'm sure that is the case but I just wish I could maximize my GPU because it is the strongest component in my system.
I'm not sure if the best bet for me would be to get a decent aircooler/heatsink and new ram and try for the best overclock or get a CPU under 200. I wouldn't want to do anything unless I could boost performance significantly, right now a 10 percent increase wouldn't do much for me.
I tend to play FPS's and RTS. I don't multitask much, just websurf, writing and gaming. Again I've never overclocked or done much system tweaking but I can print out the FAQ's and go from there...
I
Sapphire x800 XT PE
Dell 2005 FPW
I
