Greetings most exalted ones...
I have sitting in front of me an Aqua-Computer Airplex Evo 240 and a typical 240 Hardware Labs radiator as well. If I blow through both of them then there is noticeably less pressure need to go through the HWL radiator. There is also considerably more radiating surfaces available in the Aqua Computer radiator to dissipate heat and it has round tubes instead of the HWL unit with flat channels. So which one will work the best in a typical low flow situation and which will work better in a typical high flow system. Will there be any differences in actual cooling capabilities if we switch rads to the opposite camp of thought?
Ready, Set, GO!
Ready, Set, GO!
