low voltage barebone options?
Stuh505
Are there any barebone options for the ultra-low-voltage (U) or low-voltage (L) "core" series processors (core 1/2 solo/duo) in existence?
All I can find are core 2 duo T series barebones!
I think that all the L and V are soldered directly to the board without a socket. However if no low voltage barebone options exist, is the pin configuration of socket P the same so that I could remove the plastic socket and solder the processor directly onto the board?
