Low to mid range gaming computer
Durntdude
I could use some assistance with building a computer for a friend of the family. Basically the computer will be used for light/medium gaming(League of Legends, TF2, perhaps minecraft, and maybe more), live streaming, and artistic sketching. I have a good idea of the parts to buy on a high end build but for this price range, I am lost.
Med/light gaming (League of legends/tf2/minecraft) and some tablet drawing
$450-$500, after tax/shipping. Maybe a little more if it is really worth it
Orlando, FL-ish
Parenthesis are what I've decided with thus far, not set in stone. Please give any and all suggestions
Case (NZXT Source 210 S210-001 $40)
PSU (Corsair TX650 650 watt $90)
Motherboard (ASUS M5A97 R2.0 AM3+ $95)
CPU w/ heat sink (AMD Phenom II X4 965 $99)
RAM (4-8 GB of DDR3 1333 or 1600. $30-$50)
Video card(I was thinking the geforce 550ti $135ish but it may be too costly)
Case Fans may or may not be needed based on the case
Re-using hard drive, cd drive, monitor, speakers, mouse
6) Will you be overclocking?
no
1680x1200 I think
Within a week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Besides having 6 or more USB slots (including headers) and the obvious pci-e x16, nothing
yes, 64 bit windows 7
I would personally recommend using an ASUS Mainboard as opposed to the Asrock. It's not really a question of build quality for me (though there is that, too) as of the fact that ASUS makes fairly regular BIOS updates for their boards. I have found that very useful for a variety of reasons including support getting added for later gen chips that did not exist when I bought the board. Also, many (most?) ASUS AMD mainboards come with a function (Hardware switch) that "tunes" RAM so you can frequently get RAM that won't POST working without having to resort to a BIOS upgrade - this has saved my bacon a couple of times.
Ditch the Source 210 and spend the extra cash for the better Corsair 200R:
$50 - Corsair Carbide Series 200R ATX Case
Go for this RAM:
$36 - Patriot PSD38G13332 8GB DDR3 1333 RAM
I would go with a different platform altogether for faster performance:
$114 - Core i3 2120 CPU
$75 - Gigabyte GA-B75M-D3H Intel B75 mATX Motherboard
Video card wise, I recommend this faster card:
$140 - MSI N650TI PE 1GD5/OC GeForce GTX 650 TI 1GB Video Card
The above changes will put you at around $505 shipped but well worth it since you're getting higher performance.
Go for this RAM:
Dan's the man... but what about lowering the power supply, like this power supply. Don't get the $90 Corsair for a $500 build, when the $30 ECO 620W is built by Seasonic and more than enough for your needs.
I would debate the merits of a recommending a 200R over a 210, but both cases should do fine.
Also, why a i3-2120 over an i3-3220? The newer 3220 is only a few dollars more, runs with lower power and heat.
Beyond that, Dan's recommendation is pretty spot on.
Not sure where you're getting $30 from but the $50 Antec Neo Eco 620C isn't half bad.
Because I was already $5 over budget and didn't want to spend the extra $10 for a 3% performance increase. If the OP goes with your PSU recommendation though, that'll free up cash for the Core i3-3220.
Well to clairfy I gave the after rebate prices, it's $50 to start and had a $20 rebate. Looks like the final price went up by $10... I had this saved so I linked it blindy (it was supposed to be good through 1/31).
In any case, at $50 it's a seasonic-built unit with a $10 rebate. $40 net cost in the end.
EDIT: Whoa, didn't realize it's already 1/31. So yeah, time warp.
The PSU choice was not because I though I needed the wattage but because I have a distrust in any PSU under $70, I do agree that seasonic and antec are good brands so I would not be incredibly worried about a lower priced version model of theirs
As for intel vs AMD, I really am not very particular. Is the i3-2120 and i3-3220 really that much better than the phenom? The friend does want to be able to live stream games and I figured the additional 2 cores would be better in that situation, even if the architecture is not quite as good.
Motherboard-wise, I for some reason was thinking mATX's didn't ever have 4x RAM slots (which obviously) is wrong so I didn't look. I do like the board choice. In addition it is a 1155 board so possible upgrade to an ivy/sandy bridge in the future correct?
I do greatly appreciate the ideas folks
The price of a psu doesnt determine how good it is. They have shitty psus in all price ranges, just like they have quality psus in a wide price range as well, including under $70.
SkillZ covered this pretty well but I should add this: There are plenty of shitty PSUs out there that costs $100 or more.
Yes.
Correct.
