Low scores in pcmark04 PLZ HELP!!
L33T_AmD
hello all, i currently tested out my new rig on pcmark04 yet iam only recieving a score of about 3000 or so. Heres my comp specs:
A7N8X Deluxe
1 gig of mushkin pc 3500 lvl 2 ddr BH-5
+2500 xp @ 2.2 gig (/w aero 7+)
9700 pro
onboard soundstorm
1x200 gig HD
1x80 gig HD
any one know why i have such a low score?? Can someone hint me on some good bio settings for this setup?? I have no clue why its so low?!?!?! plz help asap, thanks in advance!
John
Try not to bump every hour.. ;)
As far as the answer.. I don't know. Have you tried searching google? Is all the drivers and bios updated?
Look at your OS/software environment.
I bet something is less than optimal there
What I meant was look at your Operating System (Windows) settings, such as services, drivers, etc.
And your software, like what is running in the system tray, what TSR (terminate, stay resisdent) appas are in memory, etc.
That can make a good differnece right there. Also note some versions of windows work better on some boards than others, due to the drivers for that specific OS being more robust.
EDIT: BTW I suddenly noticed it was PCmark...my bad, but I D/Led it and ran it to give you my score for comaprison...my system only has an overclocked vidcard (429.75 core, 360 mem), everything else is running at stock speeds.
My score is 3330 PcMarks.
Don't see too many PC mark scores here, when I get home though I'll run a test on my machine and see how it comes out. Just to get a better feel of how the scores run.
I actually downloaded it last nght and plan on installing it as soon as I get home.
Well I downloaded PCMARK04 this past morning and I got 2814.
lol I dont know if that's good or bad or "ok" for my system. :D
