nekrosoft13
- Jan 4, 2005
Looking for low profile ITX CPU cooler for Intel ivy bridge platform.
What you recommend?
What you recommend?
I used this for a short time. It's shorter than the stock heat sink but cooled almost exactly the same in my experience.How low-profile are you looking? What case do you need to fit this in?
I'm using a Noctua NH-L9i on my latest SFF build, but it significantly limits overclocking due to its small heat transfer capacity.
What you recommend?
Just a quick comparison. All heights are fanless.
23mm Noctua L9i/a -mfg advises against >65w TDP
44mm ThermalTake AXP100
45mm Prolimatech Samuel 17
82mm SilverStone NT06-Pro -supports push/pull fan config w/ undermount fan
Recommendation depends on the motherboard, as the CPU socket is placed differently for each of them:Looking for low profile ITX CPU cooler for Intel ivy bridge platform.
What you recommend?
What you recommend?
