Low ppd with 5762 WU
osrk
I'm only getting 2500ppd on the 5762 WU on my 9800 GTX+ I don't think this is normal I usually get 4.2k-6.6k on my 9800 gtx+'s.
Also would I be able to OC the card more if i lower the core frequency and up the shader frequency?
there have been alot of WU coming out that just destroy your ppd! my ppd fluctuates between like 15k and 25-7k depending on what my gpus have pulled down:(
There are some PPD dogs out for WUs but, my 8800GTs still produce about 4600-4800 PPD on all the 5762s I've gotten. Sounds like maybe your GTX isn't running at 3d clocks.
That's what I thought too but I double checked and they are. The GPU core is at 80C and 750mhz core clock.
hmm.. Lets kill the obvious stuff...
1. Try restarting. Maybe something funky is up with the driver.
2. Is it the only GPU in the system? If it isn't, then are they the same spec'd GPUs, i.e. same number of shaders?
3. Maybe you got a real crappy WU and in that case I'm glad it was you and not me.. hehe j/k.. well ok not really :D
1. Nope restarting didn't work.
2. it's in a 4gpu system but they're all identical cards.
3. it's seems like it, sucks to be me. only 1 hour until it's done.
Fixed it. I had done a config were FAH started as a service. I redid the config but never ended the service or disabled it, everytime i restarted it would restart too and cause havok. My cpu usage shot through the roof halving my ppd.
