Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have an older computer here without any onboard video. I'm looking for a low powered video card, something cheap. No gaming, just web browsing. Has PCI or PCI-E
Get the newest generation card you can for your budget. It might not be as powerful performance wise as a used older gen card, but since you don't care about performance it should use less energy and will likely have a longer period of driver support.
