Low light, indoors, best bets?
Gondi
I bring the cam along to the bar once every few months. The only problem is that it's really hard to get the meter/focus right in such low light situations (i'm talking dank pit)
The camera is a Oly C-750 and doesn't have an AF Assist light, unfortunately. I can use a flash, but it puts off such harsh tones and cuts the background out.
Anyone have some recommendations on some settings to try? Best thing I could come up with is setting a high ISO... Tripod/monopod isn't really a possibility since i'm drinkin too ;)
Are you sure a collapseable monopod isn't an option? Some of those can collapse down pretty far and would fit in a decently sized camera bag.
For focusing, here's an idea that might work: take the picture with the flash innitially then lock the focus (don't know how to do that on an Oly but there must be some way) and take one without a flash.
Are there manual exposure controls on the Oly? If so then here is what I would do. Go down to a basement or some other place that is about as dark as a bar and start snapping pictures. Find the lowest shutter-speed that you can take a pic at and still have enough sharpness (remember these are impromptu drunken shots, they don't need to be incredibly sharp for that kind of photography I find that I can take acceptable 1/4-1/2 second shots). Leave your camera on that setting with a low-aperature and as high of an ISO as you are willing to use and you should be able to snap decent pictures.
I guess I should have clarified. I won't be caught dead hauling a tripod of any kind around a bar ;)
Blip i'll try the basement stuff
yeah i can feel ya...digi cams = fun, embarrassing drunk pictures
digi cam + tripod = serious, incriminating pictures.
plus, when you are drinking and having fun, you just want to shoot and not really care about setting up everything.
hehehe... indeed. Another great feature in a bar is the video mode that some digis have. It's great when your buddy is doing something that you KNOW he'll regret in the morning! :D
a trick i learned is to balance cam on beer bottle, set timer so the capture doesnt take place when you push button, set long shutter times and open apeture (if manual cam)=profit
the cue ball was low light pool table shot...cam on edge of table...
as for the rest, it was a pretty dark bar, with some neat lighting effects...so i sat at a table, and balanced cam on a long neck beer bottle and this is what i took
As much as I would like to be able to get 13 second exposures to come out well, it would be tough in this place:
That's from my old cam, but it gives and idea of the lighting.. or lack thereof.
