DKTVPN said:How can I perform Low Level Format from a system, laptop or desktop, with no floppy drive? Is it doable with USB Floppy drive?
how? i was under the impression that we havent been able to do that for yearsFLECOM said:while you technically can do low-level formats
DKTVPN said:So I guess it's writting zeros to drive. How to use with Windows CD?
I did use Win XP Pro to try zeros to drive with Win XP Home on it but have no choice of writting zeros to drive, just format the whole drive. I checked the drive's manufacture and they need to put it on a floppy.
How to know my mobos are supporting USB floppy booting?
lithium726 said:uh.. you cant just format part of the disk, you gotta do the whole disk.
potroast said:not true, if you have an 80GB drive, but only create a 20GB partition, you can format just that 20GB section.
He's not saying he only wants to do part, he's saying there's no option for writing zeros, only for normal formatting. I believe if you just reformat it normally (not quick) it'll write zeros, but then again I'm not 100% sure because I've never done it (I use WD Lifeguard utility thing).
(though this was in a 7 year old 166, and none of my current systems have this feature).
just choose "format in FAT32" or "format in NTFS" without the "quick" after it. this will write zeros to the whole drive.So I guess it's writting zeros to drive. How to use with Windows CD?
DKTVPN said:If I remember correctly, format the drive (not Quick) doesn't write zeros on it because when I format only I can install windows right after that, but if I write zeros I have to format one more time before I can run windows installation.
its just a bad idea
writing zeros or a full format should be fine 99% of the time...
crazedmodder said:He's not saying he only wants to do part, he's saying there's no option for writing zeros, only for normal formatting. I believe if you just reformat it normally (not quick) it'll write zeros, but then again I'm not 100% sure because I've never done it (I use WD Lifeguard utility thing).
Ice Czar said:formatting simply removes some of the metadata (breaks the chain of pointers)
it doesnt overwrite data, which is why its possible to recover data after a format
The difference between the regular format versus the quick format is whether or not
the volume is scanned for bad sectors using the chkdsk command.
lithium726 said:oh.. so THATS why it takes so damn long.. thanks for clearing that up ice czar
Ice Czar said:you want long
try initializing a large RAID 5 array
Happy to Help![]()
Ultimate Boot CD (Freeware ISO)
would likely have the manufacturers diagnostic utility you need
if not use a single pass of DBAN or Autoclave
that's why raid controllers have the "quick init" functionlithium726 said:hahahaha, i have no reason for RAID5.. yet... but i can imagine that a TB raid5 array would take damn near a day![]()
