Hello folks,
I'm about to build a new SFF system which would work as a file/media and virtual machine server. For the media part I'm going to use Couchpotato, Sickbeard and Plex server.
Other goals include: quiet, low idle power as it will be idle 95% of the time
I most likely won't do any transcoding.
Gear I already have:
NODE 304
8Gb DDR3
Silverstone AR01 Argon HSF
Seasonic P-400 Fanless 400W ATX23
Samsung 120Gb EVO
Western Digital 3Tb
Choices:
A) Intel G3220
Asrock E3C226D2I (http://www.asrock.com/Server/overview.asp?Model=E3C226D2I)
B) Intel 4130, underclocked (headroom in case I ever need to transcode anything)
Asus H87I-PLUS
I've read that it would make no real difference between the Pentium and Haswell processors because they will roughly use the same amount of power in idle, which the system will be in most of the time.
The Asrock one is simply because of its support for ECC.
Your thoughts on this? Thanks.
NODE 304
8Gb DDR3
Samsung 120Gb EVO
Western Digital 3Tb
Choices:
A) Intel G3220
Asus H87I-PLUS
