Low end upgrade from Gf3 TI200
Ian964
I have a geforce 3 TI200 and I want to upgrade. I can't afford 150 dollar card like the 9600 pro. What would my best bang for the buck under 100 dollars?? What about the 9100, it has the same core as the 8500 but way cheaper. Is it faster then my Ti200??
Not a lot. I too am running a Ti200, and for now I have just clocked it to 220/450mhz.
That is enough to get me by. (it plays Doom3 at ~26fps at 640x480 LQ)
I plan to get a 6600GT/6800LE depending on which becomes available first.. ($199)
==>Lazn
there really isent going to be any cards worth upgradeing that ti200 with that are under $150 for a while id think, perhaps when the 9700pros drop down there but anything below a 9700pro wouldnt be a worthwhile upgrade for you. even the gf3's are still selling for barely under $100
a good thing would be to check newegg refurbs and try to grab a 9700pro or such if one comes up as those should run pretty cheap
Newegg has a 9600XT for like $153 shipped. That'd be way better than your ti200, but probably not worth the $$$. I'd hold out for the 9800Pros to go down or cough up the extra $30 now to get the one Newegg has for sale on the load page.
Blech....
Atlantis = 128bit memory
Blech!
And a 9600 non-pro non-xt at that.
Blech!!!
