low amps on power supply
i have a Hercules 400W powersupply unit with 12A on the 12+ rail. I know that this is not too much but would it suffice for a computer running one 24x?x?x cd-rw drive and a samsung floppy drive and an athlon XP 1700+ and 1 GIG of sdram and an MSI mATX mobo? i have no video card or hard drive for this computer to-be but which ones wouldn't sap up all the amps on the 12+ rail?
The 12 volt rail is only used by peripherals...hard drives...cd roms...fans...etc. It is not used much by the mobo. You should be ok.
*WRONG*
Jeez, when is that myth or old-half truth going to DIE!
It really depends on the motherboard and the chipset. Now, we can make some assumptions about his system and it's age from the fact that it's using SDRAM, but don't make blanket statements!
As for hard drives and video cards, well video cards that don't sap power are... old, or crippled. That said, in your system there isn't much of a draw on the +12v rail ATM, so you actually could probably get away with running a 9800XT 256mb Ultra Super Mega+++++
Hard Drives, well if you're only putting one in there, you'll be fine with almost anything, 'cept SCSI.
Don't worry about it, you're not really pushing the envelope so much with that system. Manufacturers like Dell and HP routinly put smaller power supplies in bigger systems, and they run just fine.
Thanks man! Yeah, I am selling the system stated to someone without a video card or HDD and he is going to use it to game. I was just wondering if it would support a decent video card but I guess it is nothing to worry about. And, yeah, I've heard about mobos taking like 8 12+ amps..CPUs 3.
BTW, selling for 100 dollars.
