Low 6950 3DMark 11 score
vroom_skies
Hey all,
I seem to be getting a tad bit of a low score. I'm hovering right around 4757 on the performance test.
Graphic drivers are at the latest 11.8.
My specs are:
- Win 7 64
- AMD 1055T at 3.75
- AMD 6950 2 GB at 840/1325
- GIGABYTE GA-880GMA-UD2H
- Crucial C300 128 GB
- G.SKILL 8 GB DDR3 1600
- Antec TP-750
Thanks in advance
Go into CCC, enable AMD overdrive and make sure to try and force +20 Powertune. Without +20 powertune it's possible your cards gpu speeds are fluctuating up and down hindering performance. Also be sure to post this in the futuremark forums as they could probably give you some handy tweaks to get your scores to where others with a similar setup are getting. Most people work at getting those higher scores instead of just running the benchmark at stock settings with stock driver settings.
It looks a tad low but not that far off. I think I hit 7400 with SLI on my stock 1075t and 2 stock 6950's.
Thanks for the info you two.
I increased the power tune to plus 20 and it made a small difference (about 200 points).
I'll check out the 3DMark forums.
Its a little low considering I hit 5291 with a 5850. It could be your cpu. What is the gpu score?
I hit 9923 with 2 6950s. I think my single 6950 score was 52XX or something in that neighborhood, not exactly sure.
I have been having problems with the latest release of 3d m 11.
I am running a 4.8ghz sandy and quad GPU's and I get a error that my system is underperforming everytime I run the damned test. I dont understand what is wrong with their current version of the software but I am betting it is a bug. I got 5000 p score when I should be getting like 11K-15K with my rig all day long probably more.
That does seem pretty low, my OC'ed and shader unlocked 6950 gets 6370+ in the performance test of 3dm11.
