1st off, I'm certainly not complaining about my GPU temperature.
I would like to understand why my VisionTek 4850 idled at 52 - 55C stock in a 22 - 25C room though.
I'm using GPU-Z to get the temperature.
Also, my case & fans are nothing special - I just have an Antec Three Hundred with (2) front 120's, (1) rear 120, (1) side 120 & the pre-installed top 140. All the fans are set on "LOW".
After setting-up a custom profile with the stock fan set @ 40% speed, the GPU temp is 42 - 45C at idle. Highest I've seen under load is 58C.
I ask because I've read many posts of 80C + idle temps.
Anyone have any thoughts?
