Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Yes I currently have a volcano 9 fan cooling my xp 2700 i was wandering if anyone knew of a much more quiter fan and does just about as good of job cooling the chip i just don't want it to be so loud anymore.... thanks.
The Volcano 9 has the ability to adjust its speed either automatically (by thermistor) or manually (via the knob it comes with), or have the fan at maximum RPMs all the time. I take it you used the last option
I've had the best luck with Antec ball-bearing fans, but many people swear by Vantec, Panaflo, Sunon ...
you could pick up a nice Zalman CNPS 7000A-AlCu for around 30 bux
it cools very well for the noise level and it should definately be a consideration for you
