Apr 11, 2004 #1 U UnfaTeFuL Limp Gawd Joined Jun 23, 2002 Messages 460 Ok, everytime I turn on my comp, it makes a beeping noise. No screen, just a black blank screen. I have no idea where to point to for the problem.
Apr 11, 2004 #2 B bent991 Limp Gawd Joined Nov 17, 2001 Messages 157 it could be an error code. If it is you can usually find an explination in the mobo manual/maker's website.
Apr 11, 2004 #3 Z Zeke Gawd Joined Apr 19, 2003 Messages 837 jump the old CMOS, and maybe try reseating your vid card.....
Apr 11, 2004 #4 A afirawker [H]ard|Gawd Joined Jun 20, 2003 Messages 1,485 That DEFINATLY sounds like a RAM error. Check your manual but its almost universal that a loud beep at startup means theres an error pertaining to your RAM. Test it with memtest 86. GL
