- Feb 27, 2001
Looking for:
2x16GB or 2x32GB DDR4 2933 SODIMM
intel i9 10900 (plain, k or whatever)
Good USB mouse & keyboard (I'm using a simple dell mouse/kb)
Dell P2217H Monitor
2tb NVME SSD x2
xbox controller(s) not sure which I need but my son ”borrowed” both from my x360 and xb1
I'm open to other trades as well, just something I can use. As shown below i'm cleaning out bigtime.
Ok, keep in mind this stuff is FOR TRADE right now. I'll edit as I go with more to be added. This is a decent list so please
Dell X1018P SVC Tag 7Z5CY42
Dell Powerconnect 2716 SVC Tag 5CGZRB1
Intellinet 560993 16 Port Gigabit POE +Switch
0FDYMF - Dell Brocade 1020 2 x Ports 10GbE PCI Express 2.0 x8 Converged Network Adapter Card x2
Wiitek SFP-2.5G-T 2.5GBaseT SPF RJ45 100m CIS
McAfee MT9103B 1000Base-T SFP x2
OSIOptics EX-SFP-1GE-T-OSI x2
4GB SFP Cable Molex Part 591-0208 10ft
CISCO 5 Meter SFP-H10GB-CU5M SFP+ 3 10GB Cable 37-0962-03
Cisco RJ45 to Serial Cable
Unifi AP-AC Square (UAP-AC) Works good, I couldn't get it to adopt with the controller, but the app makes it work fine.
Unifi UC-CK Cloud Key
StarTech.com SATABAY425BK 4 Drive 2.5in Hot Swap SAS SATA Mobile Rack Backplane
Mokerlink 2G041G 2.5GB 5 Port Switch
Sodola SL-SGT105 2.5GB 5 Port Switch
TP-Link TL-SG108 8 Port Gigabit Switch
EDIMAX EW-7288APC
Silverstone SST-FW121 Fan x2
Fractal FD-Fan140 x2
D12SM-12 Fan
Antec 120MM Fan
Kingwin CFBL-012LB Fan x2
120MM Grill x3
Panaflo FBA09A12L Fan
Thermaltake TR2 RX-550 Power Supply
8GB 12800 DDR3 Registered x40
4GB PC4 2400T DDR4 Ram x2
USB 2.0 2 Port Manual Switch x2
USB 2.0 KVM Switch
USB Serial Cable
DVI-VGA Adater x3
USB Webcam x2
RXX6000-0141E IR Receiver
RRS9002-86XXF IR Remote
Thermaltake Slim X3 Low Profile Socket 775 1156 1155 CPU Fan
Stock Type 1155 Heatsinks x5
Quadro K1200 Low Profile Video Card w/ 4x DP Adapters
Quadro K600 Low Profile Video Card x2
Dell PR02X Dock
ECS H61H2-TI ITX Mobo (full retail box) w/ i7-3770, Noctua Low Profile HSF, 2x8GB (16GB) DDR3 PC3L-12800 & Unknown Wifi
Generic Plastic ITX Case (Can get a pic if wanted)
TP-Link Arsher C3200 Wireless Router
Seasonic SS-650HT Power Supply
TP-Link TC7650 Cable Modem
Arris SB8200 Cable Modem
TrendNet TEG-S50TXE Switch
DLink DIR-615
DLink DHP-700AV Powerline Adapters 2x
GL-iNet GL-AR750 Travel Router
HP Envy DV6-7000 Fan
Ubiquiti POE-24-12w Power Supply
Sabrent USB-DH88 USB 2.0 to DVI Adapter
ST4000DMA04 4TB 3.5" HDD (Sealed New)
WDBH2D0060HNC-NRSN 6TB 3.5" HDD (Sealed New)
WD10SPSX-22A6WT0 2.5" 1TB HDD (Sealed New)
ST2000LM015 2E8174-501 2.5" 1TB HDD (Sealed New) x2
WD Green 2.5" 1TB SSD (Sealed New)
WD Blue 2.5" 500GB SSD (Sealed New) x6
-----------------------------------------Next batch!!-----------------------------------------
2GB PC3 12800 SODIMM x2
4GB PC4-266V SODIMM x2
4GB PC3L 12800 SODIMM x2
KCP421SD8/8 8GB PC4-17000 DDR4-2133 SODIMM x2
8GB PC4 2400T SODIMM
KVR16LS11/8 8GB DDR3L (PC3-12800) SODIMM
8GB PC4 266V SODIMM x2
DDR3 SODIMM to Desktop Adapters x2
MZ-MTE1280 128GB mSATA SSD
AW-NE139H WiFi Card
Toshiba Flashair 8GB Wireless SD Card
MS-9A65 PC w/ J1900 CPU, 20GB mSATA SSD, 4GB DDR3 Ram & PSU (Running pfsense)
Kingston SKC400S37/512G 512GB 2.5" SSD
2x16GB DDR4 2400 SODIMM
Z7K500-500 2.5" 1TB HDD
ST1000LM049 2.5" 1TB HDD (Fails SMART)
ST1000LM049 2.5" 1TB HDD x2
MQ01ABD100 2.5" 1TB HDD
TS7SAF100 2.5" 1TB HDD
SSDSC2KB480G8 480GB 2.5" SSD x2
Intel 520 2.5" SATA 120GB SSD x2
Samsung 830 Series SSD 512GB
BP4 240GB mSATA SSD
A1660 iPhone
A1660 iPhone
A1661 iPhone
iPhone 8
iPhone 8
A1475 32GB iPad
Dell P2217H Monitor
2tb NVME SSD x2
EDIMAX EW-7288APC
D12SM-12 Fan
Antec 120MM Fan
120MM Grill x3
USB 2.0 KVM Switch
USB Serial Cable
DVI-VGA Adater x3
USB Webcam x2
Dell PR02X Dock
DLink DIR-615
AW-NE139H WiFi Card
BP4 240GB mSATA SSD
A1660 iPhone
A1660 iPhone
A1661 iPhone
iPhone 8
iPhone 8
A1475 32GB iPad
