I emailed a 2003 word document from my work email address. I emailed it to my civilian email address. I opened up the file from my civilian email address and started to work on it. I hit the saved multiple times in Word 2007. I left the file open over night. I realized I didn't save it under "My Documents". I then used the "Save As" and saved it under "My documents" Then I went under "My Documents" to find the file was not there.
I used the searched assistant and went under advance to show all hidden documents. Then I went under each drive to look for it, but to no avail could not find it. I also looked under the temp folder also.
Any suggestions or help. This document is a transcript to a court case and I do not want to start over.
